Primaluna, good deal!?!?!
Weel, after having bought the primare, my need for a valve amp, continued, so ive sold the primare and ive got a deal in a used (9/2004) prima luna prologue two, about 100hours, in box, for 900€. I know its not a bargain (price new 1500€)
, but its a good and fair price?? i can get an new (from china) cayin a 50t for more or less 600/650 € plus taxes
, what should be best? the used primaluna or the new cayin? I have some jm labs chorus 714s (91db) and i listen to 80´s rock, pink floyd, supertramp, zz top, peter murphy and so on and my living room is 25m2 . What should be better? Thanks for the help
the prima luna is identical with the cayin ta 35 to my knowledge.so better choice would be getting an a50 or a70 for the same price directly from china.
greetings
Gerd
greetings
Gerd
Verstärker : Cayin A88T blaue JJs
CD-Player : Audionet ARTV1
Phono : Micro Seiki DQX 500
Boxen : Sonus Faber Cremona Auditor
Kabel : Dr. Megele Supernova
well, they seem similar....
the primaluna has auto bias, the others no and i have assistance, in the other hand, the a50t new would be cheaper, the a70t no, and i would have to deal with bias,
and if it comes with some problem, im f&%/%
the opera consonance 88-10 its betwwen the price of a50t and a70t and the 100-10 is at same price of a50t.
the a50t (el34) would have enough juice to my jm lab speakers??
dont worry about the bias.you only have to do it once if you wont change the output tubes.that is no problem.if you start to google you will see prima luna uses the circut of the ta 35 of cayin.it is identical.
as for the a50 / 70 opera you should first decide which tube sound you want to have.the sound of a KT66 / KT88 / PP300B / EL34 after that you can ceck your funds and decide which modell to buy.
greetings
Gerd
greetings
Gerd
The €€€€€
just allow me to an el34, the kt 88 are more expansive (cayin a 70t), the only one tht i can get, is the used primaluna two (kt88) for 900€. I was thinking in the cayin a 50t from timaudio, but im a litlle afraid from buying something from so far away
but in the shops, its price is 1300€
(half from china)
The one with 60w
is the jolida jd502b, is this anygood....? sorry but im a litle confuse
The one with 60w
that is no problem.you could take several types with 91db of your jm lab.depending on the size of your listening room KT88 would be a good choice.maybe the A88T would be a good choice.if you dont like it you can sell it for the same pricing and get yourself a different one if you order directly in china.
greetings
Gerd
greetings
Gerd
ok if there is a problem with the pricing i would recommend the jolida JD801 with 4x KT88 tubes and remote control.high output power KT88 tubes.of course you can choose the 502B also.
you can start rolling tubes if you arent satisfied with it and the pricing should be way below the cayin.
greetings
Gerd
greetings
Gerd
The 801 i dont know the price but it should be more expansive than 502b.i would recommend the jolida JD801 with 4x KT88 tubes and remote control.high output power KT88 tubes.of course you can choose the 502B also
No, its more expansive, tha cayin a50t is 810 usd with insurance and the jolida jd502b is 860usd.....you can start rolling tubes if you arent satisfied with it and the pricing should be way below the cayin
There are 2 different models, A-50T for EL34 and A-55T for KT88.
The problem is that EL34 needs a higher bias voltage for the grid. Better to realize with a switch like in the A-70T.
Regards
Regards
Zuletzt geändert von Erzkanzler am Mo 8. Aug 2005, 22:24, insgesamt 1-mal geändert.
maybe try the jolida or meixing then if you can get one cheap but for sure it would be better to invest some euros more in a cayin than saving 50 bucks and buying the other brands.
greetings
Gerd
greetings
Gerd
