hab' mal irgendwo gelesen, daß MeiXing regelrecht spezialisiert auf 845er amps ist ... insofern finde ich, daß ein Rückschluß von ihrem mittelprächigen KT88er in die Irre führen kann.
just my 2c.
Was sie auf ihrer aktualisierten homepage schreiben, klingt auch nicht von schlechten Eltern:
Meine persönliche Meinung ist, daß deren AÜs schon nicht sooo schlecht sein werden. Entscheidend mitverantwortlich für den mittelmäßigen Sound von Rolfs Jinvina war imho neben dem PP-Schaltungsaufbau die KT88 als Endröhre und eben gerade nicht die AÜs!"In order to expand the markets, we cut down our prices so that more clients can enjoy the splendid music.
All of our products are now receiving authentification of the ISO9001 quality standards.
Main features of Meixing Electronics Factory:
A. The good-looking power amplifier adopts Japan-imported 8K fine steel sheet as its case, 10mm thick aluminum alloy sheet as its face, and 1.5mm thick cool rolling steel sheet as its transformer mask.
B. The internal wiring circuit is made through completely manual lap welding with smooth and firm welding points. All the connection wires are imported American silver-plating flame retarding wires.
C. The vacuum valves are domestic Shuguang brand mating valves and imported valves from Russia, Czech and America, and only those whose electric aging time is more than 60h are chosen.
D. The electrolytic capacitors are of brands such as Siemens, Red Gem, Black Diamond, etc. The non-polarized capacitors are imported well known products such as MIT, TOP, Sulun, etc. Resistors are metallic film resistors and fine carbon film resistors made in America, France and Taiwan with good filtering and guiding performance.
E. The connectors for input and output are made in Taiwan, fabricated with copper based K gold plating, with good contact performance and oxidation resistance.
F. The output transformer is made of Japanese Z11 annealed and directed steel sheets and oxygen-free copper wires, with sufficient inductance and full sound field. In addition, Meixing Factory gives the output transformer a unique design and makes the frequency response range reach 18Hz-65kHz. On 2001 Las Vegas Audio & Electronics Fair, the power amplifier from our factory was acclaimed by foreign traders as "Amazing Audio Work"!
G. A collection of famous valves with various types. The valves that are well received by audio fans are from soup to nuts, such as 300B,845,805,211,KT88,EL34,EI84. There are more than 20 models of valve power amplifier, all for purchaser's choice.
H. Novel and distinct appearance design, noble and elegant touch, three models have been patented.
I. There are ten models have obtained international CE and CB certificate or domestic CCC certificate." © MeiXing audio
Sorry Rolf, aber ich meine, in diesem Punkt bist Du (ausnahmsweise) auf dem Holzweg, nichts für ungut.
Nach meiner Erfahrung gibt's nur eins: SE Schaltung und echte Triode, also 300B oder 845, wenn man nicht gerade 100dB LSP hat.
Also ich denke Martin, bei den Monos gibt's nicht allzuviel falsch zu machen ... gute Entscheidung!
