Sounddateien zum Testen
Rhen Dark
Beitrag von Rhen Dark »
Hallo Leute,
bin durch Zufall auf diese Seite mit Sounddateien gestoßen.
http://www.ebu.ch/en/technical/publicat ... /tech3253/
Zum Testen kann man es vielleicht gebrauchen :-)
Schönes Wochenende
Hallo Rainer,
vielen Dank!
habe eben schon einige davon heruntergeladen und auf CD gebrannt, um einen neuen DAC zu testen...
Beste Gruesse
Rhen Dark
Hallo Micha
Keine Ursache :-) Denke mit den Instrumententracks kann man gut Lautsprecher testen?
Hallo Rainer,
vielen Dank :OK:
Liest sich ein wenig wie credits auf der Tubular bells.... :wink:
Rhen Dark hat geschrieben:Hallo Micha
Dafuer sind sie gedacht.
Ich zitiere mal den langen Text von der EBU-site, welcher den Sinn der tracks erklaert - auch um die Mitleser zum Anklicken des URLs zu ermutigen :wink::
Recordings for subjective tests
One fundamental prerequisite for achieving comparable results in listening tests carried out at different places, is the use of identical test material. In response to this need, the EBU SQAM Compact Disc contains a set of audio programme signals which are recommended by the EBU for subjective test purposes.
This collection includes programme signals specially chosen to reveal to the listener impairments which have been observed in testing both analogue and digital audio systems. The variety of material gathered should enable appropriate test signals to be found for almost every task. Nevertheless, a system under test which does not reveal any deterioration when using these test signals may still be sensitive to other critical signals not included in this collection.
The test disc contains excerpts of Compact Discs and other recordings specially produced for test purposes. The short items are applicable to the A-B-A-B test procedure as recommended by the CCIR (ITU-R), and the longer excerpts are intended for a more general assessment of the behaviour of audio systems. Copies of the CD can be requested from the EBU.
(Copyright EBU - quoted from http://www.ebu.ch/en/technical/publicat ... /tech3253/)
Die European Broadcast Union hat diese tracks also zusammengestellt, um aussagekraeftige und vergleichbare subjektive zu ermoeglichen...
Beste Gruesse
future303
Beitrag von future303 »
Leider funktioniert der Link nicht.. :(
Grüsse.
Seyed
roman_p
Beitrag von roman_p »
Soooo schwer ist das suchen doch auch nicht ...
tp://tech.ebu.ch/news/ebu-cds-now-online-31oct08
future303
Danke Roman!
Grüsse.
Seyed
Zurück zu „Tuning, Zubehör“
