Vielen Dank Tim
hast Du Deinen Amp ausgephast? Wenn ja, welche Werte hattest Du ungefähr?
schluck! Gestehe, bisher nicht. Werde das auf jeden Fall noch tun, steht mir mit meinem Garrard auch noch bevor...
Und merkwürdigerweise gibt's von Shuguang auch eine 5U4G:274B: the best sounding 5U4G or 5R4GY substitute ever made, lots of inner detail, very clear
extended and open high end and good bass, the 274B engraved sound outstanding
Western Electric 274B
Western Electric 274B: The original four pin 274A was designed in the 1930s for Western Electric's 300A/300B amplifier and was redesignated 274B for use with octal sockets. Some listeners feel that this is the most magical of all rectifiers, with the ability to take any amplifier to new levels of musicality. Although there are contemporary versions on the market, the best examples are still from that company. Beware of the Sylvania 274B. It's actually a 5U4 with rotated plates and not the genuine article! Expect to pay about $600 for a pair of vintage Westerns with silk-screened logos and $1,200 for engraved base pair. New production from Western Electric will be available beginning in September, 2005.
The 274B is not only a mediocre sounding tube, people typically use it as a 5U4G replacement - where it sounds even worse.
nee, hew ick nich. Ick shull Ballistol nehmen, harrn se mi vertellt. Mienwegen geern!hess du de Röhrenstifte all insmeert mit düssen Kontaktschietzüchs? De prostata tubensis har eck ok all rutholt un dörspült un achterher infettet.
Löpt nu as gesmert.
